Aller au contenu principal
Braven BRV-1M Outer Casing Replacement
Ce dont vous avez besoin
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: étape 1, image 1 de 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: étape 2, image 1 de 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: étape 3, image 1 de 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: étape 4, image 1 de 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Erik Oliva
Membre depuis le 02/14/18
607 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 membres
6 tutoriels rédigés
Un commentaire
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 635
