Aller au contenu principal
Braven BRV-HD Charging Port Replacement
Ce dont vous avez besoin
  1. Braven BRV-HD Charging Port Replacement, Battery: étape 1, image 1 de 2 Braven BRV-HD Charging Port Replacement, Battery: étape 1, image 2 de 2
    • Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
    • Make sure the device is turned off before starting.
  2. Braven BRV-HD Charging Port Replacement: étape 2, image 1 de 1
    • Lift the front panel off of the speaker using a plastic opening tool.
  3. Braven BRV-HD Charging Port Replacement: étape 3, image 1 de 2 Braven BRV-HD Charging Port Replacement: étape 3, image 2 de 2
    • Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
  4. Braven BRV-HD Charging Port Replacement: étape 4, image 1 de 1
    • Lift the back panel off of the device with a plastic opening tool.
  5. Braven BRV-HD Charging Port Replacement: étape 5, image 1 de 2 Braven BRV-HD Charging Port Replacement: étape 5, image 2 de 2
    • Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
  6. Braven BRV-HD Charging Port Replacement: étape 6, image 1 de 1
    • Remove the outer rubber flap and the plastic side port panel.
  7. Braven BRV-HD Charging Port Replacement: étape 7, image 1 de 2 Braven BRV-HD Charging Port Replacement: étape 7, image 2 de 2
    • Place the device on its front.
    • Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
    • Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
    • These screws are difficult to reach and will require a screwdriver extension piece.
  8. Braven BRV-HD Charging Port Replacement: étape 8, image 1 de 1
    • Pull off the rubber sleeve surrounding the speaker using your hands.
    • There is adhesive binding the sleeve to the speaker and force will be required to remove the sleeve.
  9. Braven BRV-HD Charging Port Replacement: étape 9, image 1 de 1
    • Lift the black covering off of the speaker using both hands.
    • Loose screws that you were unable to remove with the screwdriver will be removed when you lift off the black covering.
  10. Braven BRV-HD Charging Port Replacement: étape 10, image 1 de 1
    • Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
    • Move any wires aside to have better access to the screws securing the battery.
  11. Braven BRV-HD Charging Port Replacement: étape 11, image 1 de 1
    • Remove the two brackets that hold down the battery using your hands.
  12. Braven BRV-HD Charging Port Replacement: étape 12, image 1 de 2 Braven BRV-HD Charging Port Replacement: étape 12, image 2 de 2
    • Use the plastic opening tool to lift up the battery.
    • Remove the battery using your hands.
    • The wires connecting the battery to the motherboard are still plugged in. Avoid pulling on the battery or these wires may break.
  13. Braven BRV-HD Charging Port Replacement: étape 13, image 1 de 1
    • Disconnect the wire attaching the battery to the motherboard.
    • There is green glue on the wire ports preventing the wires from falling out. Peel and remove this glue as necessary.
    • Be careful when pulling out the wires from their ports. The metal stems attached to the ports can break. A spudger or tweezers may help.
  14. Braven BRV-HD Charging Port Replacement, Charging Port: étape 14, image 1 de 3 Braven BRV-HD Charging Port Replacement, Charging Port: étape 14, image 2 de 3 Braven BRV-HD Charging Port Replacement, Charging Port: étape 14, image 3 de 3
    • Disconnect the three plugs attached to the plastic charging port panel.
    • Remove and replace the plastic panel with a new one.
    • Be careful in removing the 3 plugs as they can break when being pulled out of their white sockets.
    Where can I buy a new charger port ?
    rocksiffredi - Réponse
2 autres ont terminé cette réparation.
Alex Ku
Membre depuis le 09/15/16
152 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team 1-5, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 1-5, Bruce Fall 2016
CSUF-BRUCE-F16S1G5
5 membres
5 tutoriels rédigés
3 commentaires
BRV-HD Bluetooth board parts
michaeadams - Réponse
BRV-HD Bluetooth broad parts
Do you know where to find replacement parts, I need to replace the charging port on my braven HD.
br53ett - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 2,890
