Aller au contenu principal
Brentwood TS-292B Browning Dial Circuitboard Replacement
Ce dont vous avez besoin
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: étape 1, image 1 de 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: étape 1, image 2 de 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: étape 1, image 3 de 3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 2, image 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 2, image 2 de 2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 3, image 1 de 1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 4, image 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 4, image 2 de 2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 5, image 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: étape 5, image 2 de 2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Elly Ayala
Membre depuis le 09/21/18
739 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 224
