Aller au contenu principal
Brentwood TS-292B Power Cable Replacement
Ce dont vous avez besoin
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: étape 1, image 1 de 1
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. Brentwood TS-292B Power Cable Replacement: étape 2, image 1 de 1
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Brentwood TS-292B Power Cable Replacement: étape 3, image 1 de 1
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  4. Brentwood TS-292B Power Cable Replacement: étape 4, image 1 de 1
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  5. Brentwood TS-292B Power Cable Replacement: étape 5, image 1 de 1
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  6. Brentwood TS-292B Power Cable Replacement: étape 6, image 1 de 1
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
Elly Ayala
Membre depuis le 09/21/18
739 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 171
