Aller au contenu principal
Breville BKC600XL Heating Tank Replacement
Ce dont vous avez besoin
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: étape 1, image 1 de 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: étape 1, image 2 de 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: étape 1, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: étape 2, image 1 de 2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: étape 2, image 2 de 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: étape 3, image 1 de 2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: étape 4, image 1 de 2 Breville BKC600XL Heating Tank Replacement, Power Cord: étape 4, image 2 de 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: étape 5, image 1 de 2 Breville BKC600XL Heating Tank Replacement, Clear Hose: étape 5, image 2 de 2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: étape 6, image 1 de 1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
2 autres ont terminé cette réparation.
Antonio
Membre depuis le 09/26/12
120 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-3, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 4,580
