Aller au contenu principal
Breville BKC600XL Water Valve Replacement
Ce dont vous avez besoin
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: étape 1, image 1 de 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: étape 1, image 2 de 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: étape 1, image 3 de 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: étape 2, image 1 de 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: étape 3, image 1 de 3 Breville BKC600XL Water Valve Replacement, Silver Casing: étape 3, image 2 de 3 Breville BKC600XL Water Valve Replacement, Silver Casing: étape 3, image 3 de 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: étape 4, image 1 de 1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Antonio
Membre depuis le 09/26/12
120 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-3, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 membres
6 tutoriels rédigés
2 commentaires
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Réponse
Hi same question :)
Aiqui2@hotmail.com - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 5,876
