Aller au contenu principal
Brother Boutique 761 Needle Replacement
Ce dont vous avez besoin
  1. Brother Boutique 761 Needle Replacement, Needle: étape 1, image 1 de 2 Brother Boutique 761 Needle Replacement, Needle: étape 1, image 2 de 2
    • Locate the screw and turn the screw counterclockwise (left).
    • Loosen the screw gently and carefully remove the needle.
  2. Brother Boutique 761 Needle Replacement: étape 2, image 1 de 1
    • Remove the faulty needle and replace it with a new needle.
  3. Brother Boutique 761 Needle Replacement: étape 3, image 1 de 1
    • Take the new needle, place the needle carefully at the base of the opening.
    • Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
  4. Brother Boutique 761 Needle Replacement: étape 4, image 1 de 2 Brother Boutique 761 Needle Replacement: étape 4, image 2 de 2
    • Secure the needle once again. We will start to re-thread the sewing machine.
    • Place the thread on the lever with the loose piece of thread on the outside.
  5. Brother Boutique 761 Needle Replacement: étape 5, image 1 de 1
    • Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
  6. Brother Boutique 761 Needle Replacement: étape 6, image 1 de 1
    • Pull the thread down towards you in the open on the front of your machine.
    • Hook the thread at the end of the opening.
  7. Brother Boutique 761 Needle Replacement: étape 7, image 1 de 1
    • Take your thread and locate the hole that is in the needle.
    • Put the thread through the hole.
  8. Brother Boutique 761 Needle Replacement: étape 8, image 1 de 1
    • Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
    • You have now finished replacing the needle and rethreading the sewing machine.
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
Erin Juarez
Membre depuis le 10/23/23
157 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-6, Bennett Fall 2023 Membre de l'équipe Sam Houston State, Team 1-6, Bennett Fall 2023
SHSU-BENNETT-F23S1G6
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 171
