Aller au contenu principal
Brother CS-80 Tire Ring Replacement
Ce dont vous avez besoin
  1. Brother CS-80 Tire Ring Replacement, Tire Ring: étape 1, image 1 de 3 Brother CS-80 Tire Ring Replacement, Tire Ring: étape 1, image 2 de 3 Brother CS-80 Tire Ring Replacement, Tire Ring: étape 1, image 3 de 3
    • Turn off the machine.
    • Unplug both the power cord and the foot pedal.
  2. Brother CS-80 Tire Ring Replacement: étape 2, image 1 de 1
    • Slide the clear flap to the left to remove it.
  3. Brother CS-80 Tire Ring Replacement: étape 3, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 3, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 3, image 3 de 3
    • Pull the latch to detach the bobbin cover.
  4. Brother CS-80 Tire Ring Replacement: étape 4, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 4, image 2 de 2
    • Remove the bobbin from the bobbin shuttle.
  5. Brother CS-80 Tire Ring Replacement: étape 5, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 5, image 2 de 2
    • Use a flathead screwdriver to pry off the plastic plate that surrounds the bobbin shuttle.
  6. Brother CS-80 Tire Ring Replacement: étape 6, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 6, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 6, image 3 de 3
    • Open the bobbin winder cover.
    • Flip up the spool pin.
  7. Brother CS-80 Tire Ring Replacement: étape 7, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 7, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 7, image 3 de 3
    • Remove the grey bobbin winder seat from the bobbin winder shaft.
  8. Brother CS-80 Tire Ring Replacement: étape 8, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 8, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 8, image 3 de 3
    • Remove the 13 mm Phillips head screw from the left side of the bobbin winder.
    • Place the screw on a magnet (or in a tray) to ensure you don't lose it.
  9. Brother CS-80 Tire Ring Replacement: étape 9, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 9, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 9, image 3 de 3
    • Pry off the bobbin winder thread spool pin and the attached bottom plate of the bobbin winder area.
    • Use a flathead screwdriver to assist you in removing the plate.
  10. Brother CS-80 Tire Ring Replacement: étape 10, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 10, image 2 de 2
    • Remove the 8 mm Phillips screw from the metal plate to the right of the motherboard.
  11. Brother CS-80 Tire Ring Replacement: étape 11, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 11, image 2 de 2
    • Open the thread compartment.
    • Press the back level on left side of the machine to eject the thread cassette compartment.
  12. Brother CS-80 Tire Ring Replacement: étape 12, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 12, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 12, image 3 de 3
    • Remove the thread cassette compartment by pulling it up.
    • Remove the front clear shield to the thread cassette compartment holder by pulling it away from the machine.
  13. Brother CS-80 Tire Ring Replacement: étape 13, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 13, image 2 de 2
    • Remove the single 19 mm Phillips head screw from the back of the internal thread cassette compartment area.
  14. Brother CS-80 Tire Ring Replacement: étape 14, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 14, image 2 de 2
    • Turn the machine so the back is facing you.
  15. Brother CS-80 Tire Ring Replacement: étape 15, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 15, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 15, image 3 de 3
    • Remove the three large 19 mm Phillips head screws from the back left face of the machine.
  16. Brother CS-80 Tire Ring Replacement: étape 16, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 16, image 2 de 2
    • Remove the 19 mm Phillips head screw from behind the handle of the machine.
  17. Brother CS-80 Tire Ring Replacement: étape 17, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 17, image 2 de 2
    • Remove the large 19 mm Phillips screw from the bottom right of the machine.
    • You should have removed a total of five 19 mm large screws from the back face.
  18. Brother CS-80 Tire Ring Replacement: étape 18, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 18, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 18, image 3 de 3
    • Remove the 33 mm Phillips head screw by the presser foot lever.
  19. Brother CS-80 Tire Ring Replacement: étape 19, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 19, image 2 de 2
    • Slowly pull apart the two sides of the sewing machine.
    • The two halves will still be partially attached by cables on the inside. Take care not to damage any of the cables.
  20. Brother CS-80 Tire Ring Replacement: étape 20, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 20, image 2 de 2
    • Gently disconnect the ribbon cable from the motherboard.
  21. Brother CS-80 Tire Ring Replacement: étape 21, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 21, image 2 de 2
    • Disconnect the 6-pin connector from the motherboard.
  22. Brother CS-80 Tire Ring Replacement: étape 22, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 22, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 22, image 3 de 3
    • Completely pull apart the two halves of the machine.
    • Set aside the front side piece.
    • Place the back piece down so that the inside faces upwards.
  23. Brother CS-80 Tire Ring Replacement: étape 23, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 23, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 23, image 3 de 3
    • Remove the gold 9 mm Phillips screw from the front right of the motherboard.
    • Remove the two silver 7 mm Phillips head screws from the front and back of the left side of the motherboard.
  24. Brother CS-80 Tire Ring Replacement: étape 24, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 24, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 24, image 3 de 3
    • Slide out the motherboard from the white plastic motherboard housing.
    • Handle the motherboard gently to avoid damaging the circuits or connectors.
  25. Brother CS-80 Tire Ring Replacement: étape 25, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 25, image 2 de 2
    • Disconnect the 3-pin connector from the front left side of the motherboard.
  26. Brother CS-80 Tire Ring Replacement: étape 26, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 26, image 2 de 2
    • Disconnect the 4-pin connector from the left underside of the motherboard.
  27. Brother CS-80 Tire Ring Replacement: étape 27, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 27, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 27, image 3 de 3
    • Flip the motherboard over so it rests upside down and away from the balance wheel.
  28. Brother CS-80 Tire Ring Replacement: étape 28, image 1 de 2 Brother CS-80 Tire Ring Replacement: étape 28, image 2 de 2
    • Use a flathead screwdriver to pry off the tire ring.
    • The tire ring may have disintegrated and deposited black rubber on the inside of the machine. If so, clean the area with cotton swabs damp with isopropyl alcohol and paper towels. Wearing disposable gloves is recommended.
  29. Brother CS-80 Tire Ring Replacement: étape 29, image 1 de 3 Brother CS-80 Tire Ring Replacement: étape 29, image 2 de 3 Brother CS-80 Tire Ring Replacement: étape 29, image 3 de 3
    • Place the new tire ring onto its seat.
    • You may need to use a flathead screwdriver to help it seat fully.
To reassemble your sewing machine, follow the disassembly instructions in reverse order.
Edyn
Membre depuis le 04/25/24
409 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-5, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 1-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 70
Total : 119
