Introduction
If you need to access the internal components of the Brother MFC-490CW, you will have to remove the front panel of the Brother MFC-490CW. Use this guide to remove the front panel of this device.
Ce dont vous avez besoin
Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
Lift up the front panel from the device.
Gently lift up and disconnect the data cables that attach the panel to the printer.
To reassemble the front panel, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Un commentaire
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
