Aller au contenu principal
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: étape 1, image 1 de 1
    • Turn device so you are looking down at the top
  2. Brother PT-1010 Battery Replacement: étape 2, image 1 de 2 Brother PT-1010 Battery Replacement: étape 2, image 2 de 2
    • Press firmly on arrow indicator and pull panel toward you.
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: étape 3, image 1 de 1
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Brother PT-1010 Battery Replacement: étape 4, image 1 de 2 Brother PT-1010 Battery Replacement: étape 4, image 2 de 2
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. Brother PT-1010 Battery Replacement: étape 5, image 1 de 1
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Brother PT-1010 Battery Replacement: étape 6, image 1 de 1
    • Repeat step 5 to insert the last 2 batteries.
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: étape 7, image 1 de 1
    • Reinsert back panel.
Haley Sweet
Membre depuis le 10/30/14
460 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-4, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 24
Total : 4,834
