Aller au contenu principal
Brother PT-110 Printer Motor Replacement
Ce dont vous avez besoin
  1. Brother PT-110 Printer Motor Replacement, Batteries: étape 1, image 1 de 2 Brother PT-110 Printer Motor Replacement, Batteries: étape 1, image 2 de 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Printer Motor Replacement: étape 2, image 1 de 1
    • Remove the batteries.
  3. Brother PT-110 Printer Motor Replacement, Back Plate: étape 3, image 1 de 2 Brother PT-110 Printer Motor Replacement, Back Plate: étape 3, image 2 de 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Printer Motor Replacement: étape 4, image 1 de 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Printer Motor Replacement: étape 5, image 1 de 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Printer Motor Replacement: étape 6, image 1 de 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Printer Motor Replacement: étape 7, image 1 de 2 Brother PT-110 Printer Motor Replacement: étape 7, image 2 de 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Printer Motor Replacement: étape 8, image 1 de 3 Brother PT-110 Printer Motor Replacement: étape 8, image 2 de 3 Brother PT-110 Printer Motor Replacement: étape 8, image 3 de 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Printer Motor Replacement, Printer Motor: étape 9, image 1 de 1
    • Remove the motor housing.
  10. Brother PT-110 Printer Motor Replacement: étape 10, image 1 de 2 Brother PT-110 Printer Motor Replacement: étape 10, image 2 de 2
    • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
    • Total: 2 x Screws
  11. Brother PT-110 Printer Motor Replacement: étape 11, image 1 de 1
    • Remove the motor.
Kimberly Larsen
Membre depuis le 09/28/16
237 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 19
Total : 800
