Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Brother PT-110 Printer Motor Replacement
Ce dont vous avez besoin
    1. Brother PT-110 Printer Motor Replacement, Batteries: étape 1, image 1 de 2 Brother PT-110 Printer Motor Replacement, Batteries: étape 1, image 2 de 2
      • Push on the side of the cover, and remove it.
      Demander à FixBot
      Ajouter un commentaire
    2. Brother PT-110 Printer Motor Replacement: étape 2, image 1 de 1
      • Remove the batteries.
      Demander à FixBot
    1. Brother PT-110 Printer Motor Replacement, Back Plate: étape 3, image 1 de 2 Brother PT-110 Printer Motor Replacement, Back Plate: étape 3, image 2 de 2
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      Demander à FixBot
    2. Brother PT-110 Printer Motor Replacement: étape 4, image 1 de 1
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      Demander à FixBot
    3. Brother PT-110 Printer Motor Replacement: étape 5, image 1 de 1
      • Gently separate the two covers, ensuring wires are not taut.
      Demander à FixBot
    4. Brother PT-110 Printer Motor Replacement: étape 6, image 1 de 1
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      Demander à FixBot
    5. Brother PT-110 Printer Motor Replacement: étape 7, image 1 de 2 Brother PT-110 Printer Motor Replacement: étape 7, image 2 de 2
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected.
      • It may require more force than expected to disconnect the wires.
      Demander à FixBot
    6. Brother PT-110 Printer Motor Replacement: étape 8, image 1 de 3 Brother PT-110 Printer Motor Replacement: étape 8, image 2 de 3 Brother PT-110 Printer Motor Replacement: étape 8, image 3 de 3
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      Demander à FixBot
    1. Brother PT-110 Printer Motor Replacement, Printer Motor: étape 9, image 1 de 1
      • Remove the motor housing.
      Demander à FixBot
    2. Brother PT-110 Printer Motor Replacement: étape 10, image 1 de 2 Brother PT-110 Printer Motor Replacement: étape 10, image 2 de 2
      • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
      • Total: 2 x Screws
      Demander à FixBot
    3. Brother PT-110 Printer Motor Replacement: étape 11, image 1 de 1
      • Remove the motor.
      Demander à FixBot
Kimberly Larsen
Membre depuis le 09/28/16
279 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 membres
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 29
Total : 1,149
