Introduction
In this guide, you will see how to fix your broken/damaged face plate on your Brother PT-1290.
Ce dont vous avez besoin
Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
Use a spudger to aid in removing the keyboard.
Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
Now that you have removed your keyboard. Turn the device over carefully.
Pop of LCD black cover.
Use the spudger to gently press out the LCD screen.
Change out old damaged face plate with your new face plate.
