Aller au contenu principal
Brother PT-1290 Keyboard Replacement
Ce dont vous avez besoin
  1. Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: étape 1, image 1 de 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: étape 1, image 2 de 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: étape 1, image 3 de 3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290 Keyboard Replacement, Back of device: étape 2, image 1 de 3 Brother PT-1290 Keyboard Replacement, Back of device: étape 2, image 2 de 3 Brother PT-1290 Keyboard Replacement, Back of device: étape 2, image 3 de 3
    • Remove back of device and set aside.
  3. Brother PT-1290 Keyboard Replacement, Remove screws: étape 3, image 1 de 3 Brother PT-1290 Keyboard Replacement, Remove screws: étape 3, image 2 de 3 Brother PT-1290 Keyboard Replacement, Remove screws: étape 3, image 3 de 3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290 Keyboard Replacement, Remove flat panel: étape 4, image 1 de 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: étape 4, image 2 de 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: étape 4, image 3 de 3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290 Keyboard Replacement, Remove: étape 5, image 1 de 3 Brother PT-1290 Keyboard Replacement, Remove: étape 5, image 2 de 3 Brother PT-1290 Keyboard Replacement, Remove: étape 5, image 3 de 3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
Angela Araujo
Membre depuis le 10/24/14
99 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-4, Johnson Fall 2014 Membre de l'équipe Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 490
