Aller au contenu principal
Brother XM3700 Broken Needle Replacement
Ce dont vous avez besoin
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: étape 1, image 1 de 3 Brother XM3700 Broken Needle Replacement, Broken Needle: étape 1, image 2 de 3 Brother XM3700 Broken Needle Replacement, Broken Needle: étape 1, image 3 de 3
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
  2. Brother XM3700 Broken Needle Replacement: étape 2, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 2, image 2 de 2
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
  3. Brother XM3700 Broken Needle Replacement: étape 3, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 3, image 2 de 2
    • Remove the broken needle stem from the machine, and dispose of it carefully.
  4. Brother XM3700 Broken Needle Replacement: étape 4, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 4, image 2 de 2
    • Unthread the broken needle tip from the thread, and dispose of carefully.
  5. Brother XM3700 Broken Needle Replacement: étape 5, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 5, image 2 de 2
    • Select a Brother brand needle, using the needle size that works well with your fabric.
  6. Brother XM3700 Broken Needle Replacement: étape 6, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 6, image 2 de 2
    • Insert the needle with the flat side of the stem facing the back of the machine.
  7. Brother XM3700 Broken Needle Replacement: étape 7, image 1 de 1
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
  8. Brother XM3700 Broken Needle Replacement: étape 8, image 1 de 2 Brother XM3700 Broken Needle Replacement: étape 8, image 2 de 2
    • Rethread the needle and pull the thread through the back.
Congratulations! You have successfully replaced your broken needle. Happy sewing!
Nadya Verick
Membre depuis le 02/07/23
178 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-6, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 1-6, Andersen Winter 2023
UCD-ANDERSEN-W23S1G6
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 18
Total : 281
