Aller au contenu principal
Pour réparer ensemble - Je crée un compte
BulbHead Red Copper 5 Minute Chef Disassembly
Ce dont vous avez besoin
  1. BulbHead Red Copper 5 Minute Chef Disassembly, BulbHead Red Copper 5 Minute Chef: étape 1, image 1 de 1
    • Open the 5 Minute Chef.
    • Remove the two 11.9 mm screws from the black plastic piece using a Phillips #1 screwdriver.
    • Remove the two 10 mm screws from the black plastic piece using a Phillips #1 screwdriver.
    • Repeat this for the other half of the machine; this step is the same for the top and bottom half.
    Demander à FixBot
    Ajouter un commentaire
  2. BulbHead Red Copper 5 Minute Chef Disassembly: étape 2, image 1 de 1
    • Remove the four 14 mm screws from the orange hot plates on both sides of the 5 Minute Chef using a Phillips #1 screwdriver.
    Demander à FixBot
  3. BulbHead Red Copper 5 Minute Chef Disassembly: étape 3, image 1 de 2 BulbHead Red Copper 5 Minute Chef Disassembly: étape 3, image 2 de 2
    • Separate the hot plate from the red casing on the top half of the 5 Minute Chef.
    • In the red casing, remove the 5.5mm screw using a Phillips #1 screwdriver and remove the silver plate to reveal the lights.
    • The red indicator light is connected to the red wire.
    Demander à FixBot
  4. BulbHead Red Copper 5 Minute Chef Disassembly: étape 4, image 1 de 1
    • Remove the two 11.9 mm security screws from the bottom half of the machine near the power cable using a Phillips #1 screwdriver.
    Demander à FixBot
  5. BulbHead Red Copper 5 Minute Chef Disassembly: étape 5, image 1 de 1
    • Remove the two 5.5mm screws from the white piece holding down the power cable using a Phillips #1 screwdriver.
    Demander à FixBot
  6. BulbHead Red Copper 5 Minute Chef Disassembly: étape 6, image 1 de 1
    • On the bottom half of the machine, remove the single 5.5 mm screw from the silver plate on the underside of the orange hot plate using a Phillips #1 screwdriver.
    Demander à FixBot
  7. BulbHead Red Copper 5 Minute Chef Disassembly: étape 7, image 1 de 1
    • Remove the single 5.5 mm screw on the bottom that holds the red wire to the hot plate using a Phillips #1 screwdriver.
    • The order is screw, spring washer, flat washer, then the clip.
    Demander à FixBot
  8. BulbHead Red Copper 5 Minute Chef Disassembly: étape 8, image 1 de 1
    • Flip the hot plates over to the top.
    • Remove the single 5.5 mm screw from the silver plate using a Phillips #1 screwdriver.
    Demander à FixBot
  9. BulbHead Red Copper 5 Minute Chef Disassembly: étape 9, image 1 de 2 BulbHead Red Copper 5 Minute Chef Disassembly: étape 9, image 2 de 2
    • Underneath the silver plate from the previous step, remove the two 5.5 mm screws at the sides of the round white thermal switch using a Phillips #1 screwdriver.
    • The order is screw, spring washer, then washer.
    • There is thermal paste underneath the thermal switch. Be careful not to get it on anything.
    Demander à FixBot
  10. BulbHead Red Copper 5 Minute Chef Disassembly: étape 10, image 1 de 2 BulbHead Red Copper 5 Minute Chef Disassembly: étape 10, image 2 de 2
    • There are two heating elements which heat up the two orange hot plates.
    • The red indicator light is in parallel with the voltage source, so it is always on when the device is plugged in. The green indicator light is in parallel with a thermal switch which is normally closed, creating a short circuit so the green light is normally off.
    • There is thermal paste between the hot plate and the thermal switch so that heat is conducted to the switch well. When the thermal switch reaches a certain temperature, it opens, allowing current to flow through the green light, indicating that the device is hot enough to place food in.
    Demander à FixBot
Pièces jointes
Claire Muisener
Membre depuis le 09/13/25
231 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 183
