Aller au contenu principal
Bush Pump Cylinder (Shona) Replacement
  1. Bush Pump Cylinder (Shona) Replacement, Head and Handle (Shona): étape 1, image 1 de 2 Bush Pump Cylinder (Shona) Replacement, Head and Handle (Shona): étape 1, image 2 de 2
    • Ona kuti pombi inoshanda zvakanaka sei nekupomba kwemakumi mana.
    • Pombi inoshanda zvakanaka inofanira kudira mvura inosvika marita gumi.
  2. Bush Pump Cylinder (Shona) Replacement: étape 2, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 2, image 2 de 2
    • Bvisa mapini maviri akabatanidza mubato nechinofambisa mubato.
  3. Bush Pump Cylinder (Shona) Replacement: étape 3, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 3, image 2 de 2
    • Dhonza mibato miviri kubva kune chinofambisa mubato.
  4. Bush Pump Cylinder (Shona) Replacement: étape 4, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 4, image 2 de 2
    • Simudza mapini maviri akabatanidza pombi kumusoro nemubato, kubva papombi.
  5. Bush Pump Cylinder (Shona) Replacement: étape 5, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 5, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 5, image 3 de 3
    • Mudanho rino rose, ona kuti watsigira mubato nemusoro nemaoko matatu kana kupfuura.
    • Buritsa chimutanda chejoinhi kubva muchimusoro.
    • Wongorora chimutanda chejoinhi nemusoro kuti hazvina kusakara kana kukuvara here.
  6. Bush Pump Cylinder (Shona) Replacement: étape 6, image 1 de 1
    • Bvisa musoro nemubato wozviisa panzvimbo yakachena kuti zvisabate utachiona
  7. Bush Pump Cylinder (Shona) Replacement, Riser Main Slider (Shona): étape 7, image 1 de 2 Bush Pump Cylinder (Shona) Replacement, Riser Main Slider (Shona): étape 7, image 2 de 2
    • Simudza mubato mukuru unosimudza pombi zvine simba nemaoko maviri.
    • Chenjerera kuti usadonhedze mubato mukuru unosimudza pombi, nekuti izvi zvinogona kukuvadza humburumbira
  8. Bush Pump Cylinder (Shona) Replacement: étape 8, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 8, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 8, image 3 de 3
    • Shandisa chipanera chepombi kusunungura pombi inotakura mvura yepamusoro.
  9. Bush Pump Cylinder (Shona) Replacement: étape 9, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 9, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 9, image 3 de 3
    • Simudza mubato unosimudza pombi nepombi refu.
    • Tenderedza simbi inobata chimutanda chepombi pachimutanda, uye chisunge zvine simba pachimutanda chepombi.
    • Dzikisa pombi refu nemubato unosimudza pombi kuti ugare pane chinobatisa pombi zvakanaka.
  10. Bush Pump Cylinder (Shona) Replacement: étape 10, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 10, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 10, image 3 de 3
    • Sunungura ubvise bhaudhi rinobata chimutanda chepombi nebhaudhi rechimutanda chepombi pamusoro pemutanda unosimudza pombi.
  11. Bush Pump Cylinder (Shona) Replacement: étape 11, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 11, image 2 de 2
    • Bvisa mubato mukuru unosimudza pombi, uye ongorora kuti haina kubvaruka kana kuchembera here.
    • Isa mubato unosimudza pombi panzvimbo yakachena kuitira kuti usabate utachiona.
  12. Bush Pump Cylinder (Shona) Replacement, Above Grade Riser Pipe (Shona): étape 12, image 1 de 3 Bush Pump Cylinder (Shona) Replacement, Above Grade Riser Pipe (Shona): étape 12, image 2 de 3 Bush Pump Cylinder (Shona) Replacement, Above Grade Riser Pipe (Shona): étape 12, image 3 de 3
    • Bvisa pombi inotakura mvura yepamusoro.
    • Sungirira mubato wakaita saT pamutanda wepombi.
    • Kana uri kuchinja pombi yemvura yepamusoro, siya mubato wakaita saT uripo kusvikira wave kugona kuisa nhengo yekutsiva nayo.
  13. Bush Pump Cylinder (Shona) Replacement, Spout (Shona): étape 13, image 1 de 3 Bush Pump Cylinder (Shona) Replacement, Spout (Shona): étape 13, image 2 de 3 Bush Pump Cylinder (Shona) Replacement, Spout (Shona): étape 13, image 3 de 3
    • Shandisa chipanera chepombi kusunungura nekubvisa muromo wepombi.
    • Wongorora muromo kuti hapana zvakavhara kana zvingangokonzera utachiona.
    • Isa muromo panzvimbo yakachena kuti usabate utachiona.
  14. Bush Pump Cylinder (Shona) Replacement, Riser Main (Shona): étape 14, image 1 de 3 Bush Pump Cylinder (Shona) Replacement, Riser Main (Shona): étape 14, image 2 de 3 Bush Pump Cylinder (Shona) Replacement, Riser Main (Shona): étape 14, image 3 de 3
    • Isa chipanera pamusoro perimwe remabhaudhi emubato unosimudza pombi.
    • Tenderedza chimwe chipanera pazasi pebhaudhi.
    • Patsanura zvipanera kuti usunungure bhaudhi.
    • Dzokorora maitiro aya pane mabhaudhi matatu asara.
  15. Bush Pump Cylinder (Shona) Replacement: étape 15, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 15, image 2 de 2
    • Bvisa manatsi mana nemabhaudhi akabata mubato unosimudza pombi, uye uzvichengete muchinhu chisina utachiona chakaita semugoro.
  16. Bush Pump Cylinder (Shona) Replacement: étape 16, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 16, image 2 de 2
    • Tenderedza chivharo chepombi kusvika pamadhigiri makumi mana nemashanu. Izvi zvinokugonesa kuti ubate zvakanaka chivharo paunochisimudza.
  17. Bush Pump Cylinder (Shona) Replacement: étape 17, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 17, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 17, image 3 de 3
    • Nyatsosimudza zvakanaka mubato wakaita saT kwemainjisi akawanda.
    • Vamwe vanhu vaviri vakatsigira mubato wakaita saT, bvisa simbi inobatiswa nayo mubato wepombi.
    • Dzikisa mubato wakaita saT zvinyoronyoro kusvikira mubato wepombi wave kumira wega.
  18. Bush Pump Cylinder (Shona) Replacement: étape 18, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 18, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 18, image 3 de 3
    • Pombi iyi inoshandisa chinotsigira chine makumbo matatu (tiraipodhi) pamwe nezvinodhonza netambo kusimudza pombi refu. Zvipanera zvakaita saC zvinogona kushandiswawo kusimudza pombi refu
    • Nyatsosunga zvakanaka chinosimudzira pombi yemvura kumubato mukuru pasi pemuromo.
  19. Bush Pump Cylinder (Shona) Replacement: étape 19, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 19, image 2 de 2
    • Wakachenjerera kuti tambo isatsvedze, shandisa zvinodhonza mubato netambo kusimudza pombi refu kusvikira zvinosimudza pombi zvasvika pane zvinodhonza netambo.
  20. Bush Pump Cylinder (Shona) Replacement: étape 20, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 20, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 20, image 3 de 3
    • Kana pombi refu yasvika pane zvinodhonza netambo, sunga simbi inosunga nechepasi papombi refu
  21. Bush Pump Cylinder (Shona) Replacement: étape 21, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 21, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 21, image 3 de 3
    • Batisa simbi inosungiswa pasi kumubato uchishandisa bhaudhi.
    • Bhaudhi rimwechete kazhinji rakakwana kuchengetedza simbi inosungiswa pasi panzvimbo, asi unogona kushandisa rimwe bhaudhi kana uchida kunyatsochisimbisa.
  22. Bush Pump Cylinder (Shona) Replacement: étape 22, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 22, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 22, image 3 de 3
    • Wakatsigira pamusoro pepombi, nyatsofambisa chinosunga chinosimudza kubva papombi.
    • Dzikisa chinosunga chinosimudza pombi uchidzvanya nechepasi kuti tambo dzisasungane pane zvinodhonza.
  23. Bush Pump Cylinder (Shona) Replacement: étape 23, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 23, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 23, image 3 de 3
    • Isa nekusunga chinosunga chekusimudzisa kumubato unosimudza pombi kusvika pasi pasi.
  24. Bush Pump Cylinder (Shona) Replacement: étape 24, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 24, image 2 de 2
    • Kana chinosunga chekusimudzisa chanyatsosunga, sunga tambo zvine simba.
    • Wakadhonza tambo kutsigira mubato unosimudza pombi, sunungura chinosunga chepasi.
  25. Bush Pump Cylinder (Shona) Replacement: étape 25, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 25, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 25, image 3 de 3
    • Shandisa tambo kudhonza nekusimudza mubato unosimudza pombi kusvika panokwanisika.
    • Iva nechokwadi kuti tambo iri mutiraipodhi kuti isadonhe.
    • Cherechedza pamusoro petiraipodhi kuti uone kuti pombi refu yanyatsopinda munzvimbo yekutsigira.
  26. Bush Pump Cylinder (Shona) Replacement: étape 26, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 26, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 26, image 3 de 3
    • Bvisa simbi inosungiswa kubva papombi refu, wodzokorora matanho kubva pamakumi maviri netatu kusvika makumi maviri neshanu kusvikira joinhi yekutanga yave kuoneka.
  27. Bush Pump Cylinder (Shona) Replacement: étape 27, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 27, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 27, image 3 de 3
    • Kana joinhi yekutanga yave kuoneka, sungisa simbi inosungiswa pasi pazasi pejoinhi.
  28. Bush Pump Cylinder (Shona) Replacement: étape 28, image 1 de 1
    • Bvisa simbi inosungiswa chokusimudzisa kubva pamubato mukuru, wonyatsobatanidza kutiraipodhi kuti isuduruke.
  29. Bush Pump Cylinder (Shona) Replacement: étape 29, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 29, image 2 de 2
    • Chengeta chipanera chepombi mainjisi mashoma pamusoro pejoinhi padanho rino.
    • Uchishandisa chipanera, sunungura chidimbu chekutanga chepombi refu kubva pachakabata.
  30. Bush Pump Cylinder (Shona) Replacement: étape 30, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 30, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 30, image 3 de 3
    • Nyatsovhara pajoinhi kuti mvura isapfachuke kubva nepanobatana simbi kana dzapatsanurwa.
    • Uchishandisa chipanera, sunungura pombi refu kusvikira mvura yatanga kupfachuka ichimwaya kupinda mune chinodzivisa mvura kupfachuka.
    • Usarambe uchisunungura kupfuura ipapo kusvikira mvura yamira kupfachuka.
  31. Bush Pump Cylinder (Shona) Replacement: étape 31, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 31, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 31, image 3 de 3
    • Bvisa chinovhara mvura kuti isapfachuke, wopedzisa kusunungura pombi refu.
    • Bvisa chidimbu chekutanga chepombi refu nekuchisimudza chakamira mudenga, wakachitsigira pamusoro pechidimbu chacho uye uchiramba wakachiisa mugomba rinochitsigira pamusoro petiraipodhi.
  32. Bush Pump Cylinder (Shona) Replacement: étape 32, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 32, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 32, image 3 de 3
    • Kochekera nekusunga chekusungisa mutanda mainjisi mashoma pazasi pepanobatana mutanda wepombi wekutanga.
  33. Bush Pump Cylinder (Shona) Replacement: étape 33, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 33, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 33, image 3 de 3
    • Uchishandisa chipanera chinokwana pakawanda, sunungura mutanda wepombi kubva pachikamu chasara.
    • Kana joinhi raganurwa, nyatsodzikisa pombi refu pasi.
  34. Bush Pump Cylinder (Shona) Replacement: étape 34, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 34, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 34, image 3 de 3
    • Nyatsodzikisa pombi refu, yakatambarara, woiisa panzvimbo isina hutachiona, kana zvichigona zvakagara panzvimbo yakakwirira kudzivirira kubata hutachiona.
  35. Bush Pump Cylinder (Shona) Replacement: étape 35, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 35, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 35, image 3 de 3
    • Bvisa mubato wakaita saT kubva mutanda wepombi waganurwa.
    • Kochekera mubato wakaita saT kumutanda wepombi wasara.
    • Bvisa simbi inosungiswa kubva papombi refu, wodzokorora matanho kubva pamakumi maviri nepfumbamwe kusvika makumi matatu neshanu kusvikira pombi refu yabva yose, kana kuti kusvika chikamu chakadamburwa chasvikwa.
  36. Bush Pump Cylinder (Shona) Replacement, Cylinder (Shona): étape 36, image 1 de 1
    • Iva nechokwadi kuti humburumbira haiende pasi kudzivirira hutachiona
  37. Bush Pump Cylinder (Shona) Replacement: étape 37, image 1 de 3 Bush Pump Cylinder (Shona) Replacement: étape 37, image 2 de 3 Bush Pump Cylinder (Shona) Replacement: étape 37, image 3 de 3
    • Uchishandisa zvipanera zviviri zvepombi, sunungura humburumbira kubva papombi refu.
  38. Bush Pump Cylinder (Shona) Replacement: étape 38, image 1 de 2 Bush Pump Cylinder (Shona) Replacement: étape 38, image 2 de 2
    • Donza humburumbira yacho zvinyoronyoro kubva pamutanda wepombi, uchiisa pachena vharuvhu yekumusoro nevharuvhu yepasi pemugodhi wemvura.
Kuti ubatanidze mudziyo wako, tevedzera mirayiro uchitanga nekwekupedzesera.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 197
