Introduction
Pitch bends can stop working. If you cannot hear the difference in sound when you adjust the pitch blend, it may be time to replace it. This guide will show you how to replace the pitch bend on the side panel of your device.
Ce dont vous avez besoin
Flip the keyboard upside down, with the keys on a flat surface.
Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
Grab the center of the front panel with two hands and lift to remove panel.
Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
Slide the pitch bend out of the side panel.
