Aller au contenu principal
Pour réparer ensemble - Je crée un compte
CCM Hardtail Mountain Bike Inner Tube Replacement
Ce dont vous avez besoin
  1. CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: étape 1, image 1 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: étape 1, image 2 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: étape 1, image 3 de 3
    • Take the nozzle cap off to allow the tire to deflate.
    • Place the tire pump on the nozzle and press down on the nozzle.
    • You should hear a wheezing sound indicating the air is being released.
    • Squeeze the tire to check if all the air has been removed.
    Demander à FixBot
    Ajouter un commentaire
  2. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 2, image 1 de 1
    • Place the bike upside down so it’s resting on the handlebars.
    Demander à FixBot
    • Using a torque wrench with the 15mm socket, loosen the two bolts on the axle that keep the tire in place.
    Demander à FixBot
  3. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 4, image 1 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 4, image 2 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 4, image 3 de 3
    • After removing both bolts, remove both washers that protect the frame of the bike.
    Demander à FixBot
    • Pull the tire in an upward motion, releasing it from the brakes and axle.
    Demander à FixBot
    • Insert a prying tool in between the tire and metal rim and push it outward, dislodging it from the rim and making it easier to remove.
    Demander à FixBot
  4. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 7, image 1 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 7, image 2 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 7, image 3 de 3
    • Remove the outer tire off the rim.
    • When you remove the outer tire, the inner tube is also removed.
    • Remove the inner tube from inside of the tire.
    • Clean the inner section of the outer tire with a cloth, removing any debris.
    Demander à FixBot
  5. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 8, image 1 de 2 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 8, image 2 de 2
    • Using the bike pump, inflate the new inner tube until it becomes circular.
    Demander à FixBot
    • Place the new inner tube inside the inner section of the outer tire.
    Demander à FixBot
  6. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 10, image 1 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 10, image 2 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 10, image 3 de 3
    • Place the outer section of the tire back onto the metal rim.
    • Make sure to push the nozzle of the inner tube through the designated hole in the metal rim.
    • Begin to pull the tire onto the rim.
    Demander à FixBot
  7. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 11, image 1 de 2 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 11, image 2 de 2
    • Place the tire back onto the axle.
    Demander à FixBot
  8. CCM Hardtail Mountain Bike Inner Tube Replacement: étape 12, image 1 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 12, image 2 de 3 CCM Hardtail Mountain Bike Inner Tube Replacement: étape 12, image 3 de 3
    • Place the washers on both sides of the wheel.
    • Using the torque wrench and 15mm socket, tighten the bolts to the axle, making sure the tire is securely in place.
    • Using the bike pump, fill the tire with air.
    Demander à FixBot
Ligne d'arrivée
Ishan Ojha
Membre depuis le 01/16/21
280 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G11, Woodhouse Winter 2021 Membre de l'équipe York University, Team S1-G11, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G11
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 45
Total : 869
