Aller au contenu principal
CHI Original Circuit Board Replacement
Ce dont vous avez besoin
  1. CHI Original Circuit Board Replacement, Hinge Spring: étape 1, image 1 de 2 CHI Original Circuit Board Replacement, Hinge Spring: étape 1, image 2 de 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Circuit Board Replacement: étape 2, image 1 de 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Circuit Board Replacement: étape 3, image 1 de 1
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: étape 4, image 1 de 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: étape 5, image 1 de 2 CHI Original Circuit Board Replacement: étape 5, image 2 de 2
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: étape 6, image 1 de 2 CHI Original Circuit Board Replacement, Power Cord: étape 6, image 2 de 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: étape 7, image 1 de 1
    • Gently pull upwards on the connection point and disconnect the power cord.
  8. CHI Original Circuit Board Replacement, Circuit Board: étape 8, image 1 de 3 CHI Original Circuit Board Replacement, Circuit Board: étape 8, image 2 de 3 CHI Original Circuit Board Replacement, Circuit Board: étape 8, image 3 de 3
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: étape 9, image 1 de 3 CHI Original Circuit Board Replacement: étape 9, image 2 de 3 CHI Original Circuit Board Replacement: étape 9, image 3 de 3
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: étape 10, image 1 de 1
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: étape 11, image 1 de 2 CHI Original Circuit Board Replacement: étape 11, image 2 de 2
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Eric Knigga
Membre depuis le 08/23/17
215 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Freund Fall 2017 Membre de l'équipe IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 2,850
