Aller au contenu principal
CHUWI GemiBook XPro Speakers Replacement
Ce dont vous avez besoin
  1. CHUWI GemiBook XPro Speakers Replacement, Battery: étape 1, image 1 de 2 CHUWI GemiBook XPro Speakers Replacement, Battery: étape 1, image 2 de 2
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro Speakers Replacement: étape 2, image 1 de 2 CHUWI GemiBook XPro Speakers Replacement: étape 2, image 2 de 2
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro Speakers Replacement: étape 3, image 1 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 3, image 2 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 3, image 3 de 3
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro Speakers Replacement: étape 4, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro Speakers Replacement: étape 5, image 1 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 5, image 2 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 5, image 3 de 3
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro Speakers Replacement, Speakers: étape 6, image 1 de 2 CHUWI GemiBook XPro Speakers Replacement, Speakers: étape 6, image 2 de 2
    • Use tweezers or your fingernails to gently disconnect the speaker connector.
  7. CHUWI GemiBook XPro Speakers Replacement: étape 7, image 1 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 7, image 2 de 3 CHUWI GemiBook XPro Speakers Replacement: étape 7, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 4.2 mm screws that secure the speakers (two screws on each speaker).
  8. CHUWI GemiBook XPro Speakers Replacement: étape 8, image 1 de 2 CHUWI GemiBook XPro Speakers Replacement: étape 8, image 2 de 2
    • Gently pick up and remove both speakers. Be careful not to strain the wire connecting them.
JakeV
Membre depuis le 08/28/24
407 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 19
Total : 47
