Aller au contenu principal
CM Storm QuickFire Rapid Large Keycap Replacement
Ce dont vous avez besoin
  1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: étape 1, image 1 de 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: étape 1, image 2 de 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: étape 1, image 3 de 3
  2. CM Storm QuickFire Rapid Large Keycap Replacement: étape 2, image 1 de 1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid Large Keycap Replacement: étape 3, image 1 de 3 CM Storm QuickFire Rapid Large Keycap Replacement: étape 3, image 2 de 3 CM Storm QuickFire Rapid Large Keycap Replacement: étape 3, image 3 de 3
    • Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
Shiva Empranthiri
Membre depuis le 10/12/14
781 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 5,609
