Introduction
This guide will go over how to install O-rings on smaller keys on your keyboard.
Insert the keycap puller around the key you'd like to install an O-ring under.
  • Insert the keycap puller around the key you'd like to install an O-ring under.
Ajouter un commentaire
Pull cap directly upward.
  • Pull cap directly upward.
Place an O-ring around the plastic shaft located on the underside of the keycap.
  • Place an O-ring around the plastic shaft located on the underside of the keycap.
2 autre(s) ont terminé cette réparation.
Shiva Empranthiri
Membre depuis le 12/10/2014
736 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 670
