Aller au contenu principal
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
Ce dont vous avez besoin
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: étape 1, image 1 de 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: étape 1, image 2 de 2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: étape 2, image 1 de 1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 3, image 1 de 1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 4, image 1 de 1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 5, image 1 de 1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 6, image 1 de 1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 7, image 1 de 1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 8, image 1 de 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 9, image 1 de 1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: étape 10, image 1 de 1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 11, image 1 de 1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 12, image 1 de 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: étape 12, image 2 de 2
    • Desolder the wires that connect the LED to the motherboard.
Farshad Mohebban
Membre depuis le 02/10/16
524 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 1,860
