Aller au contenu principal
Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement
Ce dont vous avez besoin
  1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Rubber Casing: étape 1, image 1 de 1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 2, image 1 de 1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 3, image 1 de 1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 4, image 1 de 1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Speaker Grill: étape 5, image 1 de 1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 6, image 1 de 1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 7, image 1 de 1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 8, image 1 de 1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 9, image 1 de 1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 10, image 1 de 2 Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: étape 10, image 2 de 2
    • Finally, bend the speaker cover upward and it will slide out.
Farshad Mohebban
Membre depuis le 02/10/16
524 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 971
