Aller au contenu principal
Campbell Hausfeld FP204800 On/Off Switch Replacement
Ce dont vous avez besoin
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: étape 1, image 1 de 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: étape 1, image 2 de 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: étape 1, image 3 de 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: étape 2, image 1 de 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: étape 2, image 2 de 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: étape 3, image 1 de 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: étape 4, image 1 de 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: étape 5, image 1 de 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: étape 5, image 2 de 2
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: étape 6, image 1 de 1
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Caleb Davies
Membre depuis le 10/07/14
528 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-29, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 1,478
