Introduction
In order to complete this repair properly, you will need teflon tape to seal the threads of the thumb screw drain. Although this step seems unnecessary in some cases, it will make your compressor run more efficiently without excessive starting and stopping. The replacement of thumb screw drain is straightforward.
Outils
Pièces
Aucune pièce nécessaire.
Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
  • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
  • The thumb screw may not easily be removed due to corrosion.
Ajouter un commentaire
Apply teflon tape to the replacement thumb screw drain.
  • Apply teflon tape to the replacement thumb screw drain.
  • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
  • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
Eric
Membre depuis le 09/10/2014
387 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-29, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 198
