1. The check engine light is on
    • The check engine light is on
  2. Hooking up the scan tool to find what is wrong The scan code is: p1391 which is cam shaft sensor code .
    • Hooking up the scan tool to find what is wrong
    • The scan code is: p1391 which is cam shaft sensor code .
  3. unplug the senor wire and get a tiny ranch and take the two pots off
    • unplug the senor wire and get a tiny ranch and take the two pots off
  4. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Pull the sensor straight off
    • Pull the sensor straight off
  6. buy a new sensor
    • buy a new sensor
  7. Put the sensor in the same direction that was pointed it when you take it off
    • Put the sensor in the same direction that was pointed it when you take it off
  8. Tighten the two pots so it does not slip and plug back it
    • Tighten the two pots so it does not slip and plug back it
  9. Get the scan tools and reset it so the check engine light goes off Turn the key to on position Select erase code
    • Get the scan tools and reset it so the check engine light goes off
    • Turn the key to on position
    • Select erase code
    • Hit yes
  10. the check engine light is off
    • the check engine light is off
adel_hydey
Membre depuis le 06/03/2018
361 Réputation
2 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 21
