Introduction
To replace the scanner bar, the glass must first be removed, and then the scanner bar can be easily removed and replaced.
Ce dont vous avez besoin
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
Remove the scanner bar.
Replace the scanner bar back onto metal center bar.
2 autres ont terminé cette réparation.
Un commentaire
Hello Nick, thank you for the guide.
My CanoScan LiDE 220 has started to introduce a line down the middle of the page when I scan with VueScan. Not sure if this guide applies.
