Introduction
This guide will show you how to replace your square port by unscrewing the plastic casing that holds it, unpeeling the ribbon cable that attaches it to the case, and unplugging one end of the ribbon cable that will free the entire port.
Pièces
Aucune pièce nécessaire.
Slide the plastic opening tool under the plastic to unpeel it from the glass.
  • Slide the plastic opening tool under the plastic to unpeel it from the glass.
  • Gently pry the plastic framing from the glass.
  • Repeat on the other side.
Ajouter un commentaire
Remove the front plastic frame.
  • Remove the front plastic frame.
  • Wedge the plastic opening tool under the glass and pull up.
  • Slide the glass forward.
  • Remove the glass.
  • Unscrew the three screws that attach the grey plastic shell to the case.
  • Remove the shell from the inner square port.
  • Gently unpeel the ribbon cable from the bottom of the case.
  • Unplug the ribbon cable.
  • Remove the square port.
Shannon
Membre depuis le 28/10/2013
340 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 1-89, Diaz Fall 2013 Membre de l'équipe Clemson, Team 1-89, Diaz Fall 2013
CLEM-DIAZ-F13S1G89
1 membre
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 476
