Aller au contenu principal
Canon 7210 Fan Replacement
Ce dont vous avez besoin
  1. Canon 7210 Fan Replacement, Exterior Shell: étape 1, image 1 de 2 Canon 7210 Fan Replacement, Exterior Shell: étape 1, image 2 de 2
    • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
  2. Canon 7210 Fan Replacement: étape 2, image 1 de 3 Canon 7210 Fan Replacement: étape 2, image 2 de 3 Canon 7210 Fan Replacement: étape 2, image 3 de 3
    • Gently lift up on the shell with both hands, from the back to the front.
    • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
  3. Canon 7210 Fan Replacement, Fan: étape 3, image 1 de 1
    • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
  4. Canon 7210 Fan Replacement: étape 4, image 1 de 1
    • Remove the fan by pulling up gently from the top.
    • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
  5. Canon 7210 Fan Replacement: étape 5, image 1 de 1
    • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
  6. Canon 7210 Fan Replacement: étape 6, image 1 de 1
    • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
    • The wires will need to be cut with small wire cutters in order to completely remove the fan.
William Christian
Membre depuis le 10/05/16
331 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 9-3, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 319
