Introduction
The DM-100 is still the go-to microphone for all Legria / Vixia camcorders. This basically includes all Canon camcorders starting with "HF". The mic has a high price point of about 190$, and has a design flaw that will render it unusable after only a couple of years of use.
Symptoms: The microphone produces a rattling noise when the camera is being moved, basically rendering it useless for all other than stationary shots. This guide will give a quick fix to the problem for less than a dollar.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
You access the internals by removing the grill in the front, which is held in place by a small amount of adhesive.
Use a set of tweezers (or a pointy metallic object, I used a tiny screwdriver) and gently pull in a circular fashion not to destroy the metal girder.
Canon has used an elastic band for vibration reduction of the directional "sound pipe" (seen as a circle behind the elastic band).
The pipe visible behind the elastic is supposed to be mounted toe the inner wall with the two marked circular joints.
These incredibly weak joints are bound to break as the rubber loses its elasticity.
Rubber band is irreparable and needs to go. I scratched it out using a small, sharp screwdriver.
The culprit of the rattling noise is now apparent. A plastic cylinder stretches through the whole of the microphone, enabling the microphones forward focused / directional sound.
When the rubber band breaks because of the bad joints, this thing hits the inner side of the cylinder.
I measured the internal diameter, and found that there in total was a void of about 2mm in between the tube and the mic cylinder.
After some searching, I found a 2mm thick foam sheet for about 50 cents at a hobbyist shop.
Use this to cut a small sheet of depth of about 2 cm and length matching the inner circumference.
After some scissoring, you should have something that looks a bit like this.
Add a thin layer of glue to the yellow circle and reattach the grill and windstopper.
There! 190$ microphone fixed for less than a dollar.
The audio quality isn't affected at all.
The DM-100 is a good, but expensive microphone for all Canon camcorders. The internal suspension is broken by design, and will render the microphone unusable after 2-3 years of use.
This fix is a permanent fix to Canons poor design. Since the pipe is solid, and the foam is only reaching about 2cm into the pipe, audio quality is not affected at all.
2 commentaires
Good work, good tutorial! Can you help me? I have DM-50. How to connect it to Mini Advanced Hot Shoe? Do you have an electric circuit DM-50?
raoul.luigend@gmail.com
Hi, Raoul. I’m not sure what you’re trying to accomplish on what sort of equipment. I don’t know the DM-50, but if you have a camera with the mini hot shoe like the Legria / Vixia, you just need to slide open the compartment on the top of the camera and insert the mic firmly into the hot shoe.
