Aller au contenu principal
Canon EOS 20D Secondary Control Board (C-Board 010) Replacement
Ce dont vous avez besoin
  1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: étape 1, image 1 de 2 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: étape 1, image 2 de 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove screws from under the eyepiece cap: étape 2, image 1 de 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: étape 3, image 1 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: étape 3, image 2 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: étape 3, image 3 de 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove bottom screws: étape 4, image 1 de 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: étape 5, image 1 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: étape 5, image 2 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: étape 5, image 3 de 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: étape 6, image 1 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: étape 6, image 2 de 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: étape 6, image 3 de 3
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: étape 7, image 1 de 2 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: étape 7, image 2 de 2
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
2 autres ont terminé cette réparation.
Alec M
Membre depuis le 05/08/16
1 258 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,130
