Introduction
Removing the bottom panel is safe and only requires a screwdriver.
Pièces
Aucune pièce nécessaire.
  1. Remove the two 4.8 mm black screws above the lens on the front of the camera.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.8 mm black screw on the left side of the camera.
    • Remove the front panel by lifting it away from the camera's body.
    • Remove seven 4.25 mm black screws on the bottom panel.
    • Remove the bottom panel.
Sterling Vinson
Membre depuis le 17/04/2011
216 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,583
