Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
If the back lock-release lever is loose or broken, this will allow you to attempt to replace it.
Pièces
Aucune pièce spécifiée.
  1. Open up the battery door. Open up the battery door. Open up the battery door.
    • Open up the battery door.
  2. Remove the batteries from the camera by sliding them out into your palm. Remove the batteries from the camera by sliding them out into your palm.
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Release the side latch to open the back panel. Release the side latch to open the back panel.
    • Release the side latch to open the back panel.
  4. Remove the two black 4.5mm screws above and below the latch. Remove the two black 4.5mm screws above and below the latch.
    • Remove the two black 4.5mm screws above and below the latch.
  5. Using your finger, carefully pry open the side panel from the top of camera. Pull panel downwards to remove.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Remove the two silver 6mm Phillips #1 screws. Remove the two silver 6mm Phillips #1 screws.
    • Remove the two silver 6mm Phillips #1 screws.
  7. Flip camera over to the bottom. Remove the one 5mm Phillips #1 silver screw.
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Remove the front panel by pulling away from the side with the lever. Remove the front panel by pulling away from the side with the lever.
    • Remove the front panel by pulling away from the side with the lever.
  9. Pull off the lever by pushing up from the bottom and pulling away from the bottom. Pull off the lever by pushing up from the bottom and pulling away from the bottom. Pull off the lever by pushing up from the bottom and pulling away from the bottom.
    • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
Jordan Tang
Membre depuis le 24/01/2014
534 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-20, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 membres
11 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 6
Total : 706
