Aller au contenu principal
Canon EOS 300 Battery Door Replacement
Ce dont vous avez besoin
  1. Canon EOS 300 Battery Door Replacement, Batteries: étape 1, image 1 de 3 Canon EOS 300 Battery Door Replacement, Batteries: étape 1, image 2 de 3 Canon EOS 300 Battery Door Replacement, Batteries: étape 1, image 3 de 3
    • Open up the battery door.
  2. Canon EOS 300 Battery Door Replacement: étape 2, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 2, image 2 de 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Battery Door Replacement, Side Panel with Lever: étape 3, image 1 de 2 Canon EOS 300 Battery Door Replacement, Side Panel with Lever: étape 3, image 2 de 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Battery Door Replacement: étape 4, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 4, image 2 de 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Battery Door Replacement: étape 5, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 5, image 2 de 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Battery Door Replacement, Front Panel: étape 6, image 1 de 2 Canon EOS 300 Battery Door Replacement, Front Panel: étape 6, image 2 de 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Battery Door Replacement: étape 7, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 7, image 2 de 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Battery Door Replacement: étape 8, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 8, image 2 de 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Battery Door Replacement, Bottom Panel: étape 9, image 1 de 2 Canon EOS 300 Battery Door Replacement, Bottom Panel: étape 9, image 2 de 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Battery Door Replacement: étape 10, image 1 de 3 Canon EOS 300 Battery Door Replacement: étape 10, image 2 de 3 Canon EOS 300 Battery Door Replacement: étape 10, image 3 de 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Battery Door Replacement, Side Panel with Grip: étape 11, image 1 de 3 Canon EOS 300 Battery Door Replacement, Side Panel with Grip: étape 11, image 2 de 3 Canon EOS 300 Battery Door Replacement, Side Panel with Grip: étape 11, image 3 de 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Battery Door Replacement: étape 12, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 12, image 2 de 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Battery Door Replacement: étape 13, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 13, image 2 de 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Battery Door Replacement: étape 14, image 1 de 2 Canon EOS 300 Battery Door Replacement: étape 14, image 2 de 2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Battery Door Replacement, Battery Door: étape 15, image 1 de 3 Canon EOS 300 Battery Door Replacement, Battery Door: étape 15, image 2 de 3 Canon EOS 300 Battery Door Replacement, Battery Door: étape 15, image 3 de 3
    • Remove one black 5mm Phillips #1 screw.
3 autres ont terminé cette réparation.
Jordan Tang
Membre depuis le 01/24/14
590 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-20, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 membres
32 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 2,113
