Aller au contenu principal
Canon EOS 300 Side Panel with Lever Replacement
Ce dont vous avez besoin
  1. Canon EOS 300 Side Panel with Lever Replacement, Batteries: étape 1, image 1 de 3 Canon EOS 300 Side Panel with Lever Replacement, Batteries: étape 1, image 2 de 3 Canon EOS 300 Side Panel with Lever Replacement, Batteries: étape 1, image 3 de 3
    • Open up the battery door.
  2. Canon EOS 300 Side Panel with Lever Replacement: étape 2, image 1 de 2 Canon EOS 300 Side Panel with Lever Replacement: étape 2, image 2 de 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Side Panel with Lever Replacement, Side Panel with Lever: étape 3, image 1 de 2 Canon EOS 300 Side Panel with Lever Replacement, Side Panel with Lever: étape 3, image 2 de 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Side Panel with Lever Replacement: étape 4, image 1 de 2 Canon EOS 300 Side Panel with Lever Replacement: étape 4, image 2 de 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Side Panel with Lever Replacement: étape 5, image 1 de 2 Canon EOS 300 Side Panel with Lever Replacement: étape 5, image 2 de 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
Jordan Tang
Membre depuis le 01/24/14
590 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-20, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 membres
32 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 518
