Aller au contenu principal
Introduction
Your battery may be the cause of many problems. Knowing how to access it is very important.
  1. Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  3. Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  4. Remove the battery from inside the battery housing and set the cover aside.
    • Remove the battery from inside the battery housing and set the cover aside.
Mark
Membre depuis le 20/04/2011
93 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-9, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 3,473
