Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will instruct you how to install the flash on your camera.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Pop the flash up with your thumb Pop the flash up with your thumb
    • Pop the flash up with your thumb
  5. Unscrew the two screws on the front of the flash near the bulb cover.
    • Unscrew the two screws on the front of the flash near the bulb cover.
  6. Close the flash. Lift the flash cover off. Lift the flash cover off.
    • Close the flash.
    • Lift the flash cover off.
  7. Pull off yellow capacitor from flash wiring. Pull off yellow capacitor from flash wiring.
    • Pull off yellow capacitor from flash wiring.
  8. Remove white cocking with a razor blade, and then unsolder connection.
    • Remove white cocking with a razor blade, and then unsolder connection.
  9. Remove the flash cover to access the flash bulb. After wires are unsoldered, slide flash bulb out from housing.
    • Remove the flash cover to access the flash bulb.
    • After wires are unsoldered, slide flash bulb out from housing.
Zach
Membre depuis le 04/04/2012
40 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 membres
12 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,808
