Aller au contenu principal
Canon EOS Rebel G Grip Replacement
Ce dont vous avez besoin
  1. Canon EOS Rebel G Grip Replacement, Front Panel: étape 1, image 1 de 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: étape 2, image 1 de 2 Canon EOS Rebel G Grip Replacement: étape 2, image 2 de 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: étape 3, image 1 de 3 Canon EOS Rebel G Grip Replacement: étape 3, image 2 de 3 Canon EOS Rebel G Grip Replacement: étape 3, image 3 de 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: étape 4, image 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: étape 5, image 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: étape 6, image 1 de 2 Canon EOS Rebel G Grip Replacement: étape 6, image 2 de 2
    • Use the flat end of a spudger to pop the grip off and remove grip.
Kyle Reis
Membre depuis le 04/02/12
52 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 membres
36 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,567
