Aller au contenu principal
Canon EOS Rebel G Logic Board Replacement
Ce dont vous avez besoin
  1. Canon EOS Rebel G Logic Board Replacement, Front Panel: étape 1, image 1 de 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Logic Board Replacement: étape 2, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 2, image 2 de 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Logic Board Replacement: étape 3, image 1 de 3 Canon EOS Rebel G Logic Board Replacement: étape 3, image 2 de 3 Canon EOS Rebel G Logic Board Replacement: étape 3, image 3 de 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Logic Board Replacement, Top Panel: étape 4, image 1 de 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Logic Board Replacement: étape 5, image 1 de 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Logic Board Replacement: étape 6, image 1 de 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Logic Board Replacement: étape 7, image 1 de 3 Canon EOS Rebel G Logic Board Replacement: étape 7, image 2 de 3 Canon EOS Rebel G Logic Board Replacement: étape 7, image 3 de 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Logic Board Replacement, Back Panel: étape 8, image 1 de 1
    • Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
    • Remove the strap anchor.
  9. Canon EOS Rebel G Logic Board Replacement: étape 9, image 1 de 1
    • Unlatch the back panel.
    • Using a #00 Phillips screw driver, unscrew the six screws on the bottom of the camera.
    • One 7.4 mm Phillips screw
    • Two 6.0 mm Phillips screws
    • Two 4.4 mm Phillips screws
    • One 3.9 mm Phillips screw
  10. Canon EOS Rebel G Logic Board Replacement: étape 10, image 1 de 3 Canon EOS Rebel G Logic Board Replacement: étape 10, image 2 de 3 Canon EOS Rebel G Logic Board Replacement: étape 10, image 3 de 3
    • From the bottom of the camera push the hinge rod in with your finger.
    • Return the camera to its upright position.
    • Use pliers (or tweezers) to pull the rod out from the top.
  11. Canon EOS Rebel G Logic Board Replacement, Grip: étape 11, image 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  12. Canon EOS Rebel G Logic Board Replacement: étape 12, image 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  13. Canon EOS Rebel G Logic Board Replacement: étape 13, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 13, image 2 de 2
    • Use the flat end of a spudger to pop the grip off and remove grip.
  14. Canon EOS Rebel G Logic Board Replacement, LCD Screen: étape 14, image 1 de 2 Canon EOS Rebel G Logic Board Replacement, LCD Screen: étape 14, image 2 de 2
    • Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
  15. Canon EOS Rebel G Logic Board Replacement: étape 15, image 1 de 1
    • Lift out the LCD screen.
  16. Canon EOS Rebel G Logic Board Replacement, Logic Board: étape 16, image 1 de 1
    • Using a 00 Phillips screw driver, unscrew the 7.4 mm Phillips screw on the top of the camera.
    • Using a 00 Phillips screw driver, unscrew the 4.9 mm Phillips screw on the top of the camera.
  17. Canon EOS Rebel G Logic Board Replacement: étape 17, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 17, image 2 de 2
    • Lift the LCD mount to reveal the logic board.
  18. Canon EOS Rebel G Logic Board Replacement: étape 18, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 18, image 2 de 2
    • Using a 00 Phillips screw driver, unscrew the 4.9 mm Phillips screw on the back of the camera.
    • Using a 00 Phillips screw driver, unscrew the 5.8 mm Phillips screw on the top of the camera.
  19. Canon EOS Rebel G Logic Board Replacement: étape 19, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 19, image 2 de 2
    • Use an Exacto knife to cut the white calking on the side of the side panel
    • Pull the side panel away from the camera.
  20. Canon EOS Rebel G Logic Board Replacement: étape 20, image 1 de 2 Canon EOS Rebel G Logic Board Replacement: étape 20, image 2 de 2
    • The large cylindrical object on the right side of the board is the flash capacitor.
    • WARNING: The flash capacitor may carry high voltage, that may persist for hours or even days after the camera has been switched off and/or the battery has been removed.
    • Touching the circuit board while the capacitor still holds its charge may result in a painful electric shock that you will long remember.
    • To make the board safe to work on, short out the two marked terminals with a capacitor discharge tool or the blade of a screwdriver or similar implement (with an insulated handle!) You might have to use moderate pressure to punch through the white goop that covers one of the terminals.
    • There might be little sparks and/or an audible pop. Be careful not to short other solder connections nearby.
    • Use a multimeter to check that dangerous voltage is no longer present before you proceed.
    • Unsolder all of the wires on the top of the logic board.
  21. Canon EOS Rebel G Logic Board Replacement: étape 21, image 1 de 3 Canon EOS Rebel G Logic Board Replacement: étape 21, image 2 de 3 Canon EOS Rebel G Logic Board Replacement: étape 21, image 3 de 3
    • Lift up on the board and pull towards the grip.
  22. Canon EOS Rebel G Logic Board Replacement: étape 22, image 1 de 3 Canon EOS Rebel G Logic Board Replacement: étape 22, image 2 de 3 Canon EOS Rebel G Logic Board Replacement: étape 22, image 3 de 3
    • Flip the board over.
    • Unsolder the two wires on the bottom of the board.
Zach
Membre depuis le 04/04/12
43 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 membres
36 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 3,045
