Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This guide shows you how to install the anchors for the camera strap.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Turn Camera over.
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Lay the camera on its back.
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
    • Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
  9. Unscrew the screws that hold the remaining strap anchor.
    • Unscrew the screws that hold the remaining strap anchor.
    • Two 4.9 mm Phillips screws
Kyle Reis
Membre depuis le 02/04/2012
49 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 membres
12 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,034
