Introduction
If your LCD is cracked or not turning on replace it with this guide.
Using the plastic opening tool, pry off the top cover of the LCD assembly (within the red box in the first picture).
  • Using the plastic opening tool, pry off the top cover of the LCD assembly (within the red box in the first picture).
    • Pry around the front and side edges for the easiest removal.
Ajouter un commentaire
After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  • Completely remove the LCD by disconnecting the ribbon cable from the LCD with a gentle pull.
2 autre(s) ont terminé cette réparation.
Steven MacLean
Membre depuis le 14/01/2013
74 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 19-41, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 863
