Introduction
Replacing the LCD Display should be done when the display has been damaged or it has been determined that the LCD is no longer functioning. This will take some time. Handle the display with care once you reach the component as it is attached to several other vital components.
Ce dont vous avez besoin
Place thumb on area right next to where it says open and slide to the right to open.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Detach the Motherboard, and then gently pull the motherboard away from the screen.
