Aller au contenu principal
Introduction
Although designed for long-lasting life, rechargeable batteries will lose their ability to hold an electrical charge and must be replaced.
Pièces
Aucune pièce spécifiée.
  1. Remove the three Phillips screws (shown) located at the bottom of the camera.
    • Remove the three Phillips screws (shown) located at the bottom of the camera.
  2. Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open. Remove the memory card if it is still in the camera.
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips screwdriver to remove the Phillips screw (shown) underneath the memory card slot door.
  3. Remove the Phillips screw (shown) located inside the top of the memory card compartment.
    • Remove the Phillips screw (shown) located inside the top of the memory card compartment.
  4. Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down. Remove the batteries from the compartment.
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Unscrew the three Phillips screws (shown) located inside the battery compartment.
    • The screw on the left is longer than the other two.
  5. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  6. You should now able to remove the top lid of the camera.
    • You should now able to remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
  7. Remove the lower Phillips screw (shown) from the side of the camera.
    • Remove the lower Phillips screw (shown) from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
  8. Open and pivot the LCD screen to its widest open position. Remove the rear cover by pulling it straight away from the body of the camera.
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
  9. Unscrew the top 3.9mm, middle 2.7 mm, and bottom 2.9mm screws that hold the metal foundation covering the internal battery. See next photo for zoomed image of the boxed screw.
    • Unscrew the top 3.9mm, middle 2.7 mm, and bottom 2.9mm screws that hold the metal foundation covering the internal battery.
    • See next photo for zoomed image of the boxed screw.
  10. Remove the marked 2.9mm screw shown.
    • Remove the marked 2.9mm screw shown.
  11. Lift open the battery cover and unscrew the 3.8mm screw as shown.
    • Lift open the battery cover and unscrew the 3.8mm screw as shown.
  12. Gently lift up the plate as shown. Loosen and gently pry the internal battery with the point blade probe.
    • Gently lift up the plate as shown.
    • Loosen and gently pry the internal battery with the point blade probe.
3 autre(s) ont terminé cette réparation.
konrad
Membre depuis le 11/01/2011
217 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-31, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 membres
6 tutoriels rédigés
Excellent guide. Congratulations.
Bryn Thomas
Wales
Bryn Thomas - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 6,464
