Aller au contenu principal
Canon PowerShot ELPH 150 IS Face Plate Replacement
Ce dont vous avez besoin
  1. Canon PowerShot ELPH 150 IS  Face Plate Replacement, Back Plate/Menu Buttons: étape 1, image 1 de 2 Canon PowerShot ELPH 150 IS  Face Plate Replacement, Back Plate/Menu Buttons: étape 1, image 2 de 2
    • Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 2, image 1 de 1
    • Locate the back plate of the camera (contains the LCD screen and menu buttons).
  3. Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 3, image 1 de 2 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 3, image 2 de 2
    • To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
    • Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
  4. Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 4, image 1 de 3 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 4, image 2 de 3 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 4, image 3 de 3
    • Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 5, image 1 de 2 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 5, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
  6. Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 6, image 1 de 3 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 6, image 2 de 3 Canon PowerShot ELPH 150 IS  Face Plate Replacement: étape 6, image 3 de 3
    • Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
    • Completely remove the back plate.
Alex Larrimore
Membre depuis le 03/05/17
305 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G3, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 18
Total : 778
