Aller au contenu principal
Canon PowerShot ELPH 150 IS Card/Battery Door Replacement
  1. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: étape 1, image 1 de 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: étape 1, image 2 de 2
    • Safety First: Power down your camera by locating the ON/Off button on the top of the camera and holding it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 2, image 1 de 1
    • Locate the CARD/BATT. OPEN door on the bottom right of the camera.
  3. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 3, image 1 de 1
  4. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 4, image 1 de 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 4, image 2 de 2
    • With the backplate removed, turn the camera so that the CARD/BATT. OPEN door is face up and to the right. Press down on the door as you slide it to the right. You should hear a click which indicates that the door is unlocked and will freely open.
  5. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 5, image 1 de 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 5, image 2 de 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: étape 5, image 3 de 3
    • With the CARD/BATT. OPEN door open, and the backplate off, gently pull the door from a 90 degree angle back towards you. Once you hear a pop ( a sign that one side pin has released), you can slide the door away from you to release the pin on the other side as well. Remove door.
2 autres ont terminé cette réparation.
Morgan Forester
Membre depuis le 03/21/17
284 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G3, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G3
3 membres
5 tutoriels rédigés
Un commentaire
Do you know where I can find the sensor pin for the battery door? My Elph 150 won’t turn on and I was thinking that maybe the culprit. I tried new batteries to no avail, also no power when plugged in via usb. Otherwise any ideas what could have caused it, because the camera is in mint condition.
Kimo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 488
