Aller au contenu principal
Canon PowerShot ELPH 310 HS External Panels Replacement
Ce dont vous avez besoin
  1. Canon PowerShot ELPH 310 HS External Panels Replacement, External Panels: étape 1, image 1 de 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 2, image 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: étape 2, image 2 de 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 3, image 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: étape 3, image 2 de 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 4, image 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: étape 4, image 2 de 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 5, image 1 de 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 6, image 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: étape 6, image 2 de 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS External Panels Replacement: étape 7, image 1 de 1
    • Manually remove the front panel from the camera.
Kadie Aldridge
Membre depuis le 09/23/15
213 Réputation
2 tutoriels rédigés
Équipe
University of Alabama, Team 1-4, Sydow campbell Fall 2015 Membre de l'équipe University of Alabama, Team 1-4, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G4
4 membres
4 tutoriels rédigés
Un commentaire
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
Holland Van Ackeren - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 433
