Aller au contenu principal
Canon PowerShot ELPH330 HS Camera Case Replacement
Ce dont vous avez besoin
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: étape 1, image 1 de 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: étape 1, image 2 de 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 2, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 3, image 1 de 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 4, image 1 de 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 5, image 1 de 1
    • Using your fingers, carefully pry the case apart at the seam.
Michelle Ngo
Membre depuis le 07/23/19
595 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membre de l'équipe UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 membres
3 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 218
