Aller au contenu principal
Canon PowerShot G1 X Screen Casing Replacement
Ce dont vous avez besoin
  1. Canon PowerShot G1 X Screen Casing Replacement, Screen Casing: étape 1, image 1 de 1
    • Remove the screws on the outside of the screen case shown in the photo.
  2. Canon PowerShot G1 X Screen Casing Replacement: étape 2, image 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: étape 2, image 2 de 2
    • Remove the screws on the side of the screen casing next to the hinge on the camera.
  3. Canon PowerShot G1 X Screen Casing Replacement: étape 3, image 1 de 1
    • Remove the back side of the screen casing. When removing this back casing there will be a clear plastic piece inside, remove this as well. If this is the piece you are servicing, replace it and skip to the conclusion of this guide.
  4. Canon PowerShot G1 X Screen Casing Replacement: étape 4, image 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: étape 4, image 2 de 2
    • With the plastic piece removed, locate the screws on the outside and inside of the casing shown in the photos. Remove these screws.
  5. Canon PowerShot G1 X Screen Casing Replacement: étape 5, image 1 de 1
    • Locate the four clips on the metal piece covering the back of the screen as seen in the photo. Push each of these clips in towards the center of the piece and pull up on the metal plate.
  6. Canon PowerShot G1 X Screen Casing Replacement: étape 6, image 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: étape 6, image 2 de 2
    • Completely remove the casing from the screen and replace.
Joseph Cosgrove
Membre depuis le 02/12/17
313 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 20-1, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 591
